Burnt duct
1.7K views 13 replies 6 participants last post by  drsparky
#1 ·
30floor high rise apt for 55 n older. Fire last night. 100° yesterday and today. Always happens when it is oppressive. Everyone and their brother showed up. From fire dept, police, L&I, councilman, OEM...blah blah blah. Assessed today and got the bus duct out pretty fast. Did not know how it would be because the one section (where I think it started) was completely covered in melted chit, for lack of better word.
Started on 3rd floor and rose to just about the 5th.
Basement 208v service-conduits for to duct end box.
under 5th floor.
4th floor
4th floor
3rd fl
480v service
3rd
#4 ·
Years ago when I was an apprentice in Dayton Ohio the gear that fed a large hospital burned up. They brought in a semi trailer generator to temporary replace commercial power. I got sent to Square D in Cincinnati to get new bus plates. It was 1:00 am when I arrived. They had opened up the manufacturing plant and called a machinist in to cut out the plates from ruff stock, it was neat to watch a skilled machinist work. I got back, they got the plates and they had them back to normal by 9:00 am. Bet that was expensive.
#5 ·
I only work with residential and smaller commercial properties so looking at this and knowing from personal experience the repairs needed after a fire this is intense. Thankfully it only affected 3 floors, although the repairs look tedious and siemens is not my favourite although I mostly work with their panels and breakers (super sensitive might I add).
#7 ·
Is that common to use busduct for apartments? I work with it daily in my manufacturing facility, but would've thought it needlessly expensive for a residential application. Worst blowup I've ever seen on busduct is an outdoor duct coming from a connection cabinet to a service. Water got in, went phase to phase to phase. The piece of duct was just... Gone.
#8 ·
Very common. If you ran conduit and conductors, it is more expensive. Multiple conduits and supports/tons of conductors THAT ALSO HAVE TO BE SUPPORTED. Jboxes and the connections to multiple floor equipment. If a duct fails, you can replace a section. Also duct does not take up much room. And space is $$$$$ in buildings.
